Issue: When opening a report, you get this error:
Error: Instance is read-only
What could be happening?
The error message "Error: Instance is read-only" is related to the database. You might have received this error when attempting to run reports while a database backup is running. The process locks the database in "read-only" mode.
What can you do to fix it?
First, check to see if a backup is running and wait for it to complete to see if the issue still occurs. If you are still seeing the error afterward, then perform the following steps:
  1. Stop the Lansweeper service.
  2. Stop the database service.
  3. Start the database service.
  4. Start the Lansweeper service.
  5. Try to access a report again.
2 Comments
29898
We tried this suggestion and the issue is still the same. Is there any other suggestions? It's intermittent when we run reports.
Jantremb
I get the same error for a while.
