phil_lock
I have just upgraded to v4.0.38 of Lansweepwer with the relevant premium tools but I am finding that my admin users when they attempt to use Lsremote are getting the tick box running that asks for users permission.
Can anybosy tell me how i can default the system so that the box is not ticked as there are users that should not see we are connecting.
9 REPLIES 9
The settings are stored in HKEY_CURRENT_USER\Software\Lansweeper\remotecontrol
You can save them as a reg file.
phil_lock
So my users have to connect to the server share, then run lsremote and then make the changes - as you can imagine this is not ideal especially if they then move to any of the 1200 pc's and have to run the software to access another users pc
phil_lock
This isnt ideal as i have 8 users that use the remote tools and they connect to over 1200 machines, Also when they connect there isnt time to change any options as the connection occurs imediately so the box is there for a brief period
If you start lsremote.exe without any parameters you can click the options.
After the first time changing the settings, they will be saved in the registry.
phil_lock
How can i set that by default?
When you start lsremote without any parameters you can set all options. (remove aero, remove wallpaper, ...)
phil_lock
I have added that on the end of the definition and it seems to be working. But now i am finding that my Windows 7 users are put in basic mode when connection occurs and once the connection is cut they are left in the basic mode without any wallpaper etc. 😞
You can change the action definition
parameters:
/ap = ask permission
/np = no permission
