dschumm
So, i noticed our AP's just show as a "network device" and decided we need to clean this up. after adding the MIBs i got the OIDs scanned however the AP's don't populate. after looking at this closer i noticed that the OIDs are different for each AP (obviously) and as such lansweeper is not scanning/adding them.
Here's an example:
Scanned OID (AP Name): 1.3.6.1.4.1.9.9.513.1.1.1.1.5 (as defined by the MIB)
OID of AP: 1.3.6.1.4.1.9.9.513.1.1.1.1.5.0.93.115.7.82.160
i looked through all of our AP's they all have OID's that begin with 1.3.6.1.4.1.9.9.513.1.1.1.1.5. is there a wildcard or something i need to put on the end of these OID's in order for it to actually include these? or how do i go about scanning these properly?
Currently on Version 10.0.0.2
mgarrigou
Hi everyone,
I've found a tips he
re for scanning Cisco APs via the WLC console :
https://www.cisco.com/c/fr_ca/support/docs/wireless/3504-wireless-controller/214452-monitoring-cisco...
if you want to know how many APs you've got on your WLC controler, check this OID (1.3.6.1.4.1.9.9.618.1.8.4.0) it means clsSysApConnectCount
and if you want to how many clients are connected use this OID (1.3.6.1.4.1.9.9.618.1.8.12.0) clsMaxClientsCount
Regards,
Mathias
@mgarrigou appreciate you sharing this with the rest of the community thank you!
You're welcome @Mercedes_O , i've searched this info since 5 months... 😞 so... that's why i would share for the Community
Cheers
AlanS
Did you ever figure this out?
