Hello, I have a question in regards to the default installation path for LsAgent.
By default the LsAgent installs to the C:\Program Files (x86) folder path. I'm not sure if there is a 64-bit LsAgent available or not but beyond possible compatibility issues with the application, would LsAgent still auto-update if it were installed in the C:\Program Files folder versus the C:\Program Files (x86) folder?
