‎04-17-2023 07:29 AM - last edited on ‎04-02-2024 11:22 AM by Mercedes_O
There are a few PCs that do not run Lsagent on daily basis. During troubleshooting, it was found that there is an entry of Enabled=0 in the LsAgent.ini file of these PCs.
(1) What may cause the Enabled flag = 0? (2) Will re-install the Lsagent program renable the Lsagent automatically? If not, what's the procedure to re-enable the Lsagent?
Thanks in advanced for any input.
Example of LsAgent.ini:
[default]
Server=a.b.c.d
Port=9524
AgentKey=xxx
Enabled=0
AssetId=xxx
ComputerName=COMPUTER01
LastScan=638173155278008298
LastSent=638173155314748177
Status=Running
Version=10.0.1.1
‎08-09-2024 07:37 AM
Support has a KB for this problem and pointed it out to me.
https://community.lansweeper.com/t5/quick-tech-solutions/how-to-re-enable-disabled-lsagent-clients-i...
‎08-09-2024 04:57 PM
Thank you - looks like I triggered it by deleting the asset - I had hoped that this would trigger a rescan/reset but apparently it disables the agent.
‎08-08-2024 04:07 PM - edited ‎08-08-2024 04:10 PM
I see the same on my machines.
[default]
Server=lansweeper
Port=9524
AgentKey=
Enabled=0
AssetId=xxx
ComputerName=hostname
Status=Running
Version=11.1.10.0
‎08-07-2024 10:56 PM
Any generally applicable solutions for this or ways to prevent it? I noticed one of our machines had this setting as well. Clearing state and restarting seems to have resolved it for now.
‎04-25-2023 08:43 AM
Hello there!
Our tech support team should be able to assist you with this: https://www.lansweeper.com/contact-support/
