Showing results forĀ
Did you mean:Ā
helmut_mga
My Lansweeper Server version is 11.1.2.1 and it is a LanSweeper online installation.
I tried to import more than 100 Windows PC assets via csv-file. The import test (validation) shows everthing green.
But in Lansweeper database only a part of the csv-information is stored. No "serial number", "model", "manufacturer" are stored, but "purchase date", "date" and "po number" are stored.
What happened? The import was shown as "successful". is there a bug in this server version?
helmut_mga
Reply from Support Team
"This is a known issue in the current Lansweeper version with our import template, and a fix should be included in one of our future releases. We recommend checking our changelog for bug ID: LAN-15900 when a new version is released to ensure that a fix was included. "
helmut_mga
rinks
Change log says this was fixed in 11.1.3.0 yet I am on 11.1.4.3 and it is still not importing those fields and we just did a massive import of warehouse stock from our old database that is due for deletion. šŸ˜’
ErikT
Hello there!
Our tech support team should be able to assist you with this.
How to contact support?
Using the GatherLogs tool.
