‎07-05-2012 09:52 PM
Is there a way to Specify the password that is being used in the VNC used by LSREMOTE?
I can use the VNC viewer to connect back to a PC that already is connected to byLSREMOTE but only if I open a saved connection file that i create from LSREMOTE....
I see the password in there but I assume it's encrypted a bit since I cannot reype it in manually.
I'd rather not link to a file with a password.
ALSO is the password in the ultravnc config random based on the connected user that started LSremote or is this a default password for ALL lansweeper users?
Product Feedback
‎09-04-2015 03:45 PM
‎08-28-2015 09:16 PM
‎01-05-2013 01:21 AM
Its not a fix but maybe a workaround? 🙂
‎10-23-2012 10:11 PM
‎10-24-2012 10:35 AM
danielm wrote:
Still would like the change to be done asap.
We do not currently have a release date for this feature unfortunately. We are currently working on Lansweeper 5.0. This feature will be implemented either in Lansweeper 5.1 or a later update.
‎07-18-2012 07:27 PM
‎07-18-2012 07:35 PM
danielm wrote:
Any future plans for this?
Yes, this will be implemented, but not in the next version.
‎07-06-2012 10:50 AM
‎07-05-2012 11:16 PM
I haven't fully investigated this but it does seem to work.
Please look into having that password NOT standard on all installations (which I am assuming here). Ie a small /parameter that sets the password inside the EXE so noone sees it.
1 Example.
a) LSremote to a computer.
2) look around 🙂
3) your pc crashes or lsremote closes badly and thus the "service" does not get turned off or removed from the other pc...
4) use vnc viewer and just type the "password"
you can connect. This could be used by someone else. I do not like the idea of having the same password as others.
thank you
I guess this is more of a wishlist here.
*PS* I was looking at this because I want an easy way for 2 people to Remote into the same pc 🙂
***and I just found my answer. The original "VNCVIEWER" has a default of Not sharing connection..so it was kicking me off. since it does not save the setting Just switched to the Uvnc viewer that has that as default and usesd that.
Now I can VNCVIEWER to an already connected LSREMOTE.
