11-15-2023 08:04 AM
Hi!
We are on Lansweeper v. 11.1.1.3.
Using the drop-down menus in the "Edit ticket" window is bugged.
When I have let's say a Category sub-menu where there's listed several ticket categories then the drop-down menu extends too much so I need to scroll the whole "Edit ticket" window in order to see the items in the "Category" drop-down menu.
On the picture attached you can see marked with nr1 drop-down menu that extends out of the view and at nr2 you can see that I need to scroll the entire window to see the drop-down menu.
4 weeks ago
update to v. 11.1.7.1 still have the same issue... any fix soon , when will this feature return to how it was before ?
4 weeks ago
Hello there!
We are almost finished with our upcoming release, and if final testing goes well, we expect to have it out soon, including this fix.
3 weeks ago
Hi, can you pls let us know when the upcoming release will be available?
Thank you
3 weeks ago
Hello there!
I cannot give you an exact date, but it should be very soon, some minor bugs were found during testing, which have now been fixed and retested.
02-13-2024 03:01 PM
Same issue persists with version 11.1.1.4. Any luck in obtaining a fix?
02-13-2024 03:05 PM
We are now on version v. 11.1.4.6 and the issue still persists. No fix yet.
11-15-2023 11:37 AM
Hi there,
We have reported this issue internally.
Our development team is investigating the root cause and we hope to get a fix out soon.
We apologize for any inconvenience this may cause.
