‎06-08-2024 09:43 PM - last edited on ‎07-05-2024 11:04 AM by Mercedes_O
midweek I enabled (configruration/scanning setup/general) the extended display scanning in lansweeper 11.2.0.3. Several days passed, but the number of assets has not increased, and I don't see any more information about the monitors. The back half of the monitor information report table is completely empty (SizeInInch, MaxResolution, AspectRatio ...). I ran scanning jobs, direct asset scans but nothing happend. What do I need to do to make it work?
Thanks, Zoltan.
Solved! Go to Solution.
‎06-12-2024 04:12 PM
Dears,
Our development team is investigating. It seems that the extended display information is not fetched correctly in some cases. We hope to resolve this as soon as possible.
We regret the inconvenience this is causing.
Dears,
‎06-10-2024 11:33 PM
We are having this issue as well. I've done several manual scans and verified that the monitors have been re-scanned, but no additional info. Nearly all of our monitors are from Dell.
‎06-11-2024 04:19 AM
Create support case
‎06-11-2024 11:18 AM
Yes, I tried to, but got this error message:
Now I waiting them to fix my account problem.
‎06-10-2024 12:01 PM
1. check /Scanning/Itemwaittime/ monitor - 1 time per day, for example
2. click assets type overview - monitor - rescan assets
‎06-10-2024 01:33 PM
1. I have already set the monitor scan time to 1 day.
2. I run the rescan on assets type overview - monitor, but I got no additional informations.
‎06-10-2024 01:36 PM - edited ‎06-10-2024 01:37 PM
Try this report:
Select Top (1000000) tsysOS.Image As icon,
tblAssets.AssetID,
tblMonitor.MonitorManufacturer As [Manufacturer Monitor],
tblMonitor.MonitorModel,
tblMonitor.SerialNumber,
tblMonitor.ManufacturedDate,
tblAssets.Domain,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tblAssets.Description,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.Location,
tsysIPLocations.IPLocation,
tsysOS.OSname As OS,
tblAssets.SP,
tblAssets.Firstseen As [Created at],
tblAssets.Lastseen As [Last successful scan],
tblExtendedDisplayUni.SizeInInch,
tblExtendedDisplayUni.MaxResolution,
tblExtendedDisplayUni.AspectRatio,
tblExtendedDisplayUni.ResponseTimeInMs,
tblExtendedDisplayUni.HDType,
tblExtendedDisplayUni.DisplayTech,
tblExtendedDisplayUni.RefreshRate,
tblExtendedDisplayUni.Panel,
tblExtendedDisplayUni.HeightinCm,
tblExtendedDisplayUni.WidthInCm,
tblExtendedDisplayUni.DiagonalInCm,
tblExtendedDisplayUni.HasSpeakers,
tblExtendedDisplayUni.HasCamera,
tblExtendedDisplayUni.HasUsbHub,
tblExtendedDisplayUni.UsbUpstream,
tblExtendedDisplayUni.NrOfUsbUpstream,
tblExtendedDisplayUni.UsbTypeADownstream,
tblExtendedDisplayUni.NrOfVGA,
tblExtendedDisplayUni.NrOfDVI,
tblExtendedDisplayUni.NrOfHdmi,
tblExtendedDisplayUni.HDMIVersion,
tblExtendedDisplayUni.NumberOfDisplayPorts,
tblExtendedDisplayUni.DisplayPortVersion,
tblExtendedDisplayUni.EnergyClass,
tblExtendedDisplayUni.SDRPer1000u,
tblExtendedDisplayUni.AverageWattUsage,
tblExtendedDisplayUni.StandByWattUsage,
tblExtendedDisplayUni.MaxWattUsage,
tblExtendedDisplayUni.WattUsageWhenOff,
tblExtendedDisplayUni.WattPowerSave,
tblExtendedDisplayUni.ACVoltage,
tblExtendedDisplayUni.ACFreqInHz,
tblExtendedDisplayUni.CurrentInA,
tblExtendedDisplayUni.CreationDate
From tblAssets
Inner Join tblMonitor On tblMonitor.AssetID = tblAssets.AssetID
Left Outer Join tsysIPLocations On tsysIPLocations.LocationID =
tblAssets.LocationID
Left Outer Join tblExtendedDisplayUni On
tblExtendedDisplayUni.ExtendedDisplayUniId =
(Select tblAssetCustom.ExtendedDisplayUniId
From tblAssetCustom Inner Join tblAssets On tblAssets.AssetID =
tblAssetCustom.AssetID
Where tblAssets.AssetUnique = 'Mon:' + tblMonitor.MonitorManufacturer +
':' + tblMonitor.SerialNumber)
Order By tblAssets.AssetName
do you have any filled fields righter 'Last successful scan'?
‎06-10-2024 04:18 PM
No. It is empty. This is my problem.
‎06-11-2024 04:20 AM - edited ‎06-11-2024 04:20 AM
Create support case to resolve your problem
