Showing results forĀ
Did you mean:Ā
aydinvaliyev15
few days ago i updated version to 12.3.2.3 and then scanning got slowed down and also database size before upgrading 2 gb left but now only 800 mb left. Assets are the same number almost . how this even sizing up like this . thanks in advance
2 ACCEPTED SOLUTIONS
Mister_Nobody
Honored Sweeper III
See DB Size
https://LS_server_name/Configuration/DatabaseOptions/
LS 12.3 has hidden firewall rules scanner.
Disable it via scan interval settings.
Obi_1_Cinobi
Hello there!
There are two known issues with firewall scanning.
Firewall scanning - database size issues
This issue has been escalated to our developers as bug ID LAN-17268. As @Mister_Nobody pointed out, you can temporarily disable this scan item under Scanning > Scanned Item Interval to stop the database growth: https://community.lansweeper.com/t5/scanning-your-network/manage-scanned-item-intervals/ta-p/64335
Firewall scanning - performance issues
The performance issues with the firewall scanning scan item have been resolved in Lansweeper version 12.3.2.5:
  • LAN-17132 Improved Windows Firewall Scanning Performance.
You can update to the latest Lansweeper version by following the steps in this guide: https://www.lansweeper.com/knowledgebase/updating-your-installation/
If needed, you can always check our changelog to see all the additions, changes, and fixes that have been implemented in the Lansweeper software: https://www.lansweeper.com/changelog.aspx
7 REPLIES 7
Obi_1_Cinobi
Hello there!
aydinvaliyev15
Disabling firewall features is the solution of slowing down . Just in case , i have just one problem about database sizing up . i am in touch with lansweeper support team .
Mister_Nobody
Honored Sweeper III
See DB Size
Thanks it works for me . It took approximately 2 minutes per machine and i have a lot of assets . i disabled this and scan got very quickly . i just got one problem .
Thanks .i am gonna try this way and share results with you
FrankSc
The main thing to see is which table is causing this exponential growth. This can be seen under Configuration\Database tables.
It seems you are in contact with our Support team. They should be able to identify and assist you furhter.
Yes i am in touch with your support team . I hope everything is gonna be okay. Thanks in advance
