‎02-10-2025
02:34 PM
- last edited
4 weeks ago
by
Obi_1_Cinobi
few days ago i updated version to 12.3.2.3 and then scanning got slowed down and also database size before upgrading 2 gb left but now only 800 mb left. Assets are the same number almost . how this even sizing up like this . thanks in advance
Solved! Go to Solution.
Features
General Discussion
Question
Scanning
‎02-11-2025 04:27 AM
See DB Size
https://LS_server_name/Configuration/DatabaseOptions/
LS 12.3 has hidden firewall rules scanner.
Disable it via scan interval settings.
a month ago
Hello there!
There are two known issues with firewall scanning.
Firewall scanning - database size issues
This issue has been escalated to our developers as bug ID LAN-17268. As @Mister_Nobody pointed out, you can temporarily disable this scan item under Scanning > Scanned Item Interval to stop the database growth: https://community.lansweeper.com/t5/scanning-your-network/manage-scanned-item-intervals/ta-p/64335
Firewall scanning - performance issues
The performance issues with the firewall scanning scan item have been resolved in Lansweeper version 12.3.2.5:
- LAN-17132 Improved Windows Firewall Scanning Performance.
You can update to the latest Lansweeper version by following the steps in this guide: https://www.lansweeper.com/knowledgebase/updating-your-installation/
If needed, you can always check our changelog to see all the additions, changes, and fixes that have been implemented in the Lansweeper software: https://www.lansweeper.com/changelog.aspx
- The latest Lansweeper installer can be found here: https://www.lansweeper.com/update-lansweeper/
- The latest LsAgent installers can be found here: https://www.lansweeper.com/download/lsagent/
a month ago
Hello there!
‎02-11-2025 09:25 AM
Disabling firewall features is the solution of slowing down . Just in case , i have just one problem about database sizing up . i am in touch with lansweeper support team .
See DB Size
‎02-11-2025 09:22 AM
Thanks it works for me . It took approximately 2 minutes per machine and i have a lot of assets . i disabled this and scan got very quickly . i just got one problem .
‎02-11-2025 06:57 AM
Thanks .i am gonna try this way and share results with you
‎02-10-2025 03:50 PM
The main thing to see is which table is causing this exponential growth. This can be seen under Configuration\Database tables.
It seems you are in contact with our Support team. They should be able to identify and assist you furhter.
Yes i am in touch with your support team . I hope everything is gonna be okay. Thanks in advance
