swsswr
how is it possible to map a whole bunch of assets to a specific group? E.g. I want to map all assets with nam estarting abc-XXX to be in group Group1. Group1 was indivually created already.
cheers, swsswr
Obi_1_Cinobi
Hello there!
That is indeed correct. Dynamic groups are an on-prem feature only.
The closest thing that we have in the cloud would be custom views: https://community.lansweeper.com/t5/6-views-reports-dashboards/custom-views/ta-p/67086
swsswr
this look interesting. Is this feature only available in the local console or in the cloud as well?
Obi_1_Cinobi
Hello there!
I cannot find any information about the asset groups in the cloud version
i have created a group, but how do I add assets to a group?
now all devices are just "windows" devices.
i want a default split between Desktops and laptops.
how can i achieve this?
Obi_1_Cinobi
Hello there!
If you require further assistance, please contact support: https://www.lansweeper.com/contact/contact-support/
Obi_1_Cinobi
Hello there!
Have you looked into using dynamic asset groups?
https://community.lansweeper.com/t5/managing-assets/grouping-assets/ta-p/64337
