10-18-2022 03:52 PM
Hello, hope you all are doing well.
I'm getting the error in the subject line when clicking the "Change Groups" under User Roles in User & Access Roles page. The page spins for a few seconds and then
Error code: SBOX_FATAL_MEMORY_EXCEEDED
This happens in any browser used.
Using a MS SQL DB backend
Version 10.2.5.0
Thank you for any help.
10-19-2022 09:10 PM
It was the size of the zip file was causing it to be blocked. Sent a smaller file and it went through.
10-20-2022 10:10 AM
Hello there!
Should there be a need to transfer larger files for your existing support case, we do offer an upload form for files up to 250 MB: https://www.lansweeper.com/upload-case/
10-19-2022 10:54 AM
Hello there!
Would you mind contacting our technical support team? More details on how to log a support case can be found here: https://www.lansweeper.com/contact-support/
10-19-2022 07:56 PM
Thank you for the response. Emailed support and received this error. Might have been the files attached. They were zipped.
support@lansweeper.com (support@lansweeper.com)
Your message wasn't delivered because the recipient's email provider rejected it.
