03-12-2024 06:47 PM
We have some new switches: 6200F 24G & 48G CL4 4SFP+370W Switches
They have 2 VLANs the default which is #1 and a guest wireless VLAN #125
When a switch is selected in Lansweeper the VLAN column only shows the default VLAN
All the ports are configured with both VLANs
Firmware has been updated
I have guest wireless devices running through this switch so the VLAN 125 works
Lansweeper will display multiple VLANs on our older Procurve and Aruba switches
Our Observium server can detect both VLANS on these switches.
Any suggestions?
Ken
Solved! Go to Solution.
03-15-2024 10:40 AM
Hi @KHoegeman
Make sure that the switches are scanned successfully. Here are our knowledge base articles:
Network device scanning requirements
If you continue to see the same behavior, our tech support team should be able to assist you with this.
05-29-2024 03:42 PM
Dears
Same problem here on 6100 switches. Differently on 2530 everything shows correctly
05-30-2024 10:34 AM
If what's written in the previous answer from @ErikT did not solved the issue, you need to open a ticket with Support
03-15-2024 10:40 AM
Hi @KHoegeman
