Tobias88
We have a problem, where the connected port on the switch is not updating the asset name but both are scanned successfully
Let me explain the scenario:
- PC_1 is connected to Switch_1 Port C9
- PC_1 is disconnected from Switch_1 Port C9 and reconnected to Switch_1 Port A9
- Switch_1 sees Port C9 down (red circle) and Port A9 up (green circle)
- Assetname from PC_1 is not moved from Port C9 to A9
We are using Lansweeper Version 11.4.0.4
2 ACCEPTED SOLUTIONS
FrankSc
Dear,
On the page of a switch, there is an option called "remove disconnected devices". If you click on that and then rescan the switch, the information should be updated.
ErikT
@Tobias88
Unfortunately, this cannot be activated to run automatically after each scan
Tobias88
Thank you, this worked great!
Is it possible to do that on every scan automatically?
ErikT
@Tobias88
FrankSc
Dear,
