iamhuman
Hi there!
We've been using Lansweper on-prem in the free plan for a while now with enabled LSAgent Relay.
Last friday I've got an "Assets stuck on LsAgent relay server" mail; I've checked the lansweeper web console and it says:
"This feature is disabled for your license type. Learn how you can enable this feature."
We're still <100 assets and I can't find any information about a change in the plan/features anywhere.
Or is there a difference between the legacy "LimitedTrial" Plan and the new free plan?
Did I miss any news or is the message missleading and its a different issue?
David_GF
Hi @Mr_Ken
The LsAgent relay is not available in freeware mode.
Sweep that LAN, sweep it!
10 REPLIES 10
David_GF
hi @iamhuman
That's right; you need a license key to use the Relay. That's the case when installing Lansweeper without a trial key. You can request one here: https://www.lansweeper.com/product/on-prem/
Sorry to jump in here, but we have the same issue.  I've followed the link from David_GF entered our details and unless I'm missing something there's no license key issued afterwards?
iamhuman
Sorry, I should have added more details to my reply..
I neither got a key via the link - I ended up using the contact form to ask for a new key(I added my expired trial key) and got a new trial key.
The new key worked in the "add license setting" and the LsAgent relay is active again. I'd expect(hope) this key to work like the old key - after trial runs out it changes to "free mode".
I'm still not 100% if thats expected behaviour or an error, but just didn't want to bother the forum. Since I see the abstract "contact support for a (new) key" I guess it is somewhat exprected behaviour that the trial keys(or the "free license" with this keys) expire after some time(updates/years?).
Does LSAgent relay work with your expired trial (free) key as our instance has reverted to how it was before so I just wanted to check before contacting support.
Thanks.
David_GF
Hi @Mr_Ken
Sig
while I kinda understand the decision to remove features it would be great if it was still possible to deactivate the relay after the downgrade. I'm currently stuck with a scanning server I can't delete because it's set up as relay, which I can't turn off..
TVBanks98
@Sig, did you ever get this resolved.  I'm in the same boat after a server migration for a hardware upgrade.  I cannot get rid of the old decommissioned scan server because it;s stuck activated as a relay server on the free license and I cannot deactivate it.
Sig
It's been a while.. I think I backed up my installation, set up a new server and migrated without a problem. Relay is still active, but doesn't impede any operations. What are you stuck on?
TVBanks98
Same.  I migrated to new hardware but I am stuck with the old asset configured as a Relay Server under a feature that is greyed-out because I am on the free license.  There does not seem to be any way to clean that mess up.  I want to completely decommission that asset, but am afraid to do so until I can get it completely removed as a Relay Server.
I may contact sales to see if I can get a short-term trial license to get the feature re-enabled so it can be cleaned up.
