The branch tool allows you to add branching logic to your Workflow.
Think of branches as logical paths that your Workflow can take.
Given some information about a previous step's results, your Workflow can follow one of many paths.
Branch steps are useful when you need to conditionally execute certain steps.
Here are a couple of examples of what you can accomplish with branching:
Example 1: The webhook requests your Workflow receives could contain a "Widget Created", "Widget Updated", or "Widget Deleted" event.
You need to execute a series of steps depending on which event type was received.
Example 2: You want to upsert data into a system that doesn't support upsert.
You can check if a record exists and branch into "add a new record" or "update the existing record" branches depending on whether the record exists.
Branching on a value
A simple branch action branches on a value.
If you've done any programming, it's very similar to the switch/case construct present in many programming languages.
You declare "this step result will have one of these values - follow a branch based on which value it is."
Consider Example 1 above.
Suppose the webhook request you receive has an HTTP header, event, that can be one of three values: widget-created, widget-updated, or widget-deleted.
You can look at that value and branch accordingly.
.png?sv=2022-11-02&spr=https&st=2025-10-31T11%3A11%3A06Z&se=2025-10-31T11%3A26%3A06Z&sr=c&sp=r&sig=LLts7QkWklXxt7vRR7dJJsQt9PfM0DPPI7jMMDNRFoE%3D)
If your Workflow receives a widget-created event header, it will follow the "Created" branch, etc.
Branching on an expression
The Branch on Expression action allows you to create branches within your Workflow based on more complex inputs.
You can compare step results or static values using comparison operators (like "does not equal" or "less than") and follow a branch based on the results of the comparisons.
Branch on expression comparison operators
Comparison operators allow you to compare two properties to one another.
You can test if the two values are equal, if one value is contained within the other (assuming the second value is a list), if one timestamp is before another timestamp, etc.
If your comparison evaluates to true (for example, if you use the equals operator and both values are 5), the branch associated with that comparison within your Workflow is followed.
Equals
The equals operator evaluates if two fields are equal to one another, regardless of type.
| Left Field |
Right Field |
Result |
Comments |
5.2 |
5.2 |
true |
5.2 |
5 |
false |
"5.2" |
5.2 |
true |
Strings are cast to numbers when compared to numbers |
"Hello" |
"Hello" |
true |
"Hello" |
"hello" |
false |
String comparison is case-sensitive |
false |
0 |
true |
Boolean false evaluates to 0, and true evaluates to 1. |
[1,2,3] |
[1,2,3] |
true |
Arrays whose elements are the same are considered equal |
{"foo":"bar"} |
{"foo":"bar"} |
true |
Objects with the same keys/values are equal |
Does not equal
The does not equal operator evaluates if two fields are not equal to one another, regardless of type.
| Left Field |
Right Field |
Result |
5.3 |
5.2 |
true |
[1,2,3] |
[1,2,4] |
true |
Is greater than
The is greater than operator evaluates if the left field is greater than the right field, and is an implementation of the JavaScript greater than operator.
| Left Field |
Right Field |
Result |
Comments |
5.2 |
5.3 |
false |
5.3 |
5.3 |
false |
The values are equal; one is not greater than the other |
"5.3" |
5.2 |
true |
"Hello" |
"World" |
false |
Strings are compared alphabetically - "Hello" does not occur after "World" |
"hello" |
"World" |
true |
The ASCII value for "h" occurs after "W" |
true |
false |
true |
true (1) is greater than false (0) |
Is greater than or equal to
The is greater than or equal to operator is similar to is greater than, but also returns true if the values being compared are equal to one another.
| Left Field |
Right Field |
Result |
Comments |
5.3 |
"5.3" |
true |
Is less than
The is less than operator evaluates if the left field is less than the right field.
| Left Field |
Right Field |
Result |
Comments |
3 |
4 |
true |
"abc" |
"daa" |
true |
"a" is less than "d" alphabetically |
Is less than or equal to
The is less than or equal to operator is similar to is less than, but also returns true if the values being compared are equal to one another.
Contained in
The contained in operator evaluates if the value of the left field is contained in the right field.
The right field must be an array or a string.
| Left Field |
Right Field |
Result |
Comments |
"world" |
"Hello, world!" |
true |
"World" |
"Hello, world!" |
false |
2 |
[1,2,3] |
true |
"2" |
[1,2,3] |
false |
The string "2" does not occur in the array of numbers [1,2,3] |
Not contained in
The not contained in operator evaluates if the value of the left field does not appear in the right field.
| Left Field |
Right Field |
Result |
2 |
[1,2,3] |
false |
'Hi' |
'Hello' |
true |
Is empty
The is empty operator evaluates if the given value is an empty string or an empty array.
| Field |
Result |
true |
"hello" |
false |
true |
[1,2,3] |
false |
Exactly matches
The exactly matches operator evaluates if the two fields are equal to one another, taking type of the values into consideration.
| Left Field |
Right Field |
Result |
Comments |
"5" |
5 |
false |
The string "5" is not equal to the number 5 |
Does not exactly match
The does not exactly match operator evaluates if the if the two fields are not equal to one another, taking type of the values into consideration.
| Left Field |
Right Field |
Result |
Comments |
"5" |
5 |
true |
Starts the string
The starts the string operator evaluates if the the right field's value begins with the left field's value.
Both right and left values must be strings.
| Left Field |
Right Field |
Result |
Comments |
"Test" |
"Testing Value" |
true |
"test" |
"Testing Value" |
false |
Comparisons are case-sensitive |
"Test" |
"A Testing Value" |
false |
The right field must start with the left value (not merely contain it) |
Does not start the string
The does not start the string operator returns the opposite of the starts with operator.
Ends the string
The ends the string operator evaluates if the right field ends with the left field.
| Left Field |
Right Field |
Result |
orld! |
Hello, World! |
true |
orld |
Hello, World! |
false |
Does not end the string
The does not end the string operator returns the opposite of the ends with operator.
Is after (date/time)
The is after (date/time) operator attempts to parse the left and right fields as dates, and evaluates if the left field occurs after the right field.
| Left Field |
Right Field |
Result |
Comments |
"2021-03-20" |
"2021-04-13" |
false |
"2021-03-20T12:50:30.105Z" |
"2021-03-20T11:52:21.881Z" |
true |
When dates are equivalent, time is compared |
"2021-03-20" |
1631568050 |
false |
1631568050 is the UNIX epoch time for 2021-09-13, which occurs after 2021-03-05 |
Note: Accepted DateTime Formats
The time comparison operators accept date/times as ISO strings (like 2021-03-20 or 2021-03-20T11:52:21.881Z), Unix epoch timestamps in milliseconds (for example, the number 1631568050 represents a time in 2021-09-13), or Date() JavaScript objects.
Is before (date/time)
The is before (date/time) operator attempts to parse the left and right fields as dates, and evaluates if the left field occurs before the right field.
Is the same (date/time)
The is the same (date/time) operator attempts to parse the left and right fields as dates, and evaluates if the timestamps are identical.
| Left Field |
Right Field |
Result |
Comments |
true |
"2021-03-20T12:50:30Z" |
1616244630000 |
true |
1616244630 is the millisecond UNIX epoch representation of March 20, 2021 12:50:30 |
"2021-03-20T12:50:31Z" |
false |
Is true
The is true operator evaluates if an input field is "truthy".
Common "truthy" values include true, "true", "True", "Yes", "yes", "Y" and "y".
Common "falsy" values include false, "false", "False", "No", "no", "N" and "n" and evaluate to false.
Other values that evaluate to false are 0, null, undefined, NaN and "".
All other values (a non-zero number, a non-empty string, any array or object, etc.) evaluates to true.
| Field |
Result |
"Yes" |
true |
"True" |
true |
true |
true |
"Hello" |
true |
-5 |
true |
"n" |
false |
false |
false |
false |
null |
false |
0 |
false |
Is false
The is false operator returns the opposite of the is true operator.
Does not exist
The does not exist operator evaluates to true if the presented value is one of the following: undefined, null, 0, NaN, false or "".
| Field |
Result |
undefined |
true |
NaN |
true |
1 |
false |
"Hello" |
false |
Exists
The exists operator returns the opposite of the does not exist operator.
Combining multiple comparison operators
Multiple expressions can be grouped together with And or Or clauses, which execute like programming and and or clauses.
Take, for example, this programming expression:
if ((foo > 500 and bar <= 20) or ("b" in ["a","b","c"]))
The same logic can be represented with a group of conditionals in a Branch on Expression action:
