We're moving! Please visit our new Knowledge Center for the latest documentation or read more about what's changing here.
Article link copied to clipboard
Updated
Published
1 min read
This component allows a flow to call itself with a cursor in order to process large amounts of data in serial.
Triggers
Recursive Trigger
Accept a request from an 'Invoke Recursive Trigger' step
Input Comments Default
Run on Deploy? Run this flow automatically when an instance is deployed. false
Default Cursor Value The default value to return as a cursor if no cursor was supplied in a trigger payload. For example, you could set this to '1970-01-01T00:00:00Z' (Unix Epoch) if your cursor is a creation timestamp, or '0' if your cursor is a page number.
Actions
Get Recursive Cursor
Get the current value of the recursive trigger cursor
Invoke the current flow with the current cursor
Set Recursive Cursor
Set the value of the recursive cursor for the next loop iteration or recursive trigger invocation
Cursor The programmatic cursor to set for the next loop iteration or recursive trigger invocation.
